Hue Adjustments : add randomize
I like to add very small variations of color to multiple elements at the end of the design to make it more lively while keeping it in a limited palette.
It would be great to have a randomization function added to the Hue Adjustment dialog, like we have on the Transform dialog (transform each / randomize tick boxes).
I know we can randomize colors with the Colorize function, but having the ability to set precise amounts for H, S and L independently would be more intuitive and direct. I hope this could be done
@EricP I added this to the backlog as a feature and will try to find a solution (maybe for 1.3).
Meanwhile, you may want to try the Effects -> Replace Colors -> Disturb Colors for random color adjustment.Also: the "fade" option in the Colorizer can be used to change the current object colors just a bit.
Here is a trick I used when creating a pattern
https://www.vectorstyler.com/forum/topic/4347/just-a-pattern/24
@VectorStyler thanks for the backlog add. And thanks for reminding me about randomization in Disturb Colors, I had overlooked it.
@Subpath thanks for sharing these tricks and nice tutorials
