Transparency panel & blends
@VectorStyler Using the ‘Transparency’ panel, one can change the way a shape blends with an underlying layer. Would it be possible for VS to show the absence of blending (Normal) by default when the mouse pointer moves away from the list? For the moment, one need to move the pointer back to Normal.
Thanks
@B-Vs-V Currently when the mouse is hovered over an item in the blend mode list, the preview of the blend is activated.
This stays on if the mouse is moved away, but it is restored when the list is closed (without selecting the item).Should it restore also if the mouse moves outside the list?
@VectorStyler IMHO, yes, it would speed up the process (instead of closing the list or hovering over another blend). Thanks.
