Shortcut set in VectorStyler->Keyboard Shortcuts not displaying on menu
Title:
Custom shortcuts assigned via Customize Shortcuts do not appear on menusDescription:
I’ve assigned a custom shortcut (e.g., Command-4 for Show All) using the VectorStyler → Customize Shortcuts dialog.
 The shortcut works as expected — I can use Command-4 to trigger Show All.
 However, the Command-4 shortcut does not display next to the Show All command in the menus.This makes it harder to verify or remember assigned shortcuts during normal use.
Expected behavior:
After assigning a shortcut via Customize Shortcuts, the corresponding menu entry should display that shortcut next to the command, just like default shortcuts do.Version:
VectorStyler 1.073 (Mac)Why it matters:
This would align VectorStyler with standard macOS app behavior (e.g., Illustrator, Affinity) and improve usability for users who customize their shortcuts.
@jpsimmons Yes, this can be replicated and it is a bug. I will try to fix it for the next build.
