list of errors
@monsterfox I will try to fix these.
@VectorStyler I wonder if you have tested with the file I provided. Currently, the error in shape selection still persists, and it seems somewhat difficult to resolve.
@monsterfox Yes I tested it. If you try to overlap the two shapes they are different, that causes the small relative movement between the parts of the shape.
Is there some other error I'm not aware of?
@VectorStyler said in list of errors:
So far, the only issues found are the two mentioned in my video.
@VectorStyler https://youtu.be/mAvJ112O928?feature=shared
I'll mainly talk about Issue 2: When two shapes are blended, undoing one step of the operation while they are in the blended state will cause one of the shapes to disappear, and it cannot be recovered.
This post is deleted!
@monsterfox said in list of errors:
I did not yet fix this. I will try to replicate and fix for the next build.
@VectorStyler https://youtu.be/wMf28fMFx_0?feature=shared
I have pinned the custom toolbar to the top-left corner. When I drag the right panel bar, the tools on the left jitter. This issue does not occur when the custom toolbar is removed, and I hope this can be fixed.
@monsterfox I will try to replicate and fix this.
@VectorStyler https://youtu.be/gBMnHHnm1Fk?feature=shared
 I set a shortcut key for the Align Panel and added the panel to the Mini Panel Bar. Here are the operations that cause errors: Use the shortcut key to open the Align Panel, then press the Alt+P shortcut to open the Path Panel, and drag the Path Panel into the Align Panel to form a panel group. At this point, the shortcut key for the Align Panel will fail; if you press Alt+P again to open the Path Panel, you'll find that two identical panels appear. (The same issue occurs when replacing the Path Panel with the Blend Panel.)
@VectorStyler https://youtu.be/mkdtbDXrmTU?feature=shared
0_1759675136200_gy.vstyler
1. There are still issues with the Node Simplification tool: sometimes it doesn’t work, and other times it functions normally at the initial stage of operation but fails later on.
2. The Offset Path tool works fairly well when operated in the middle of a single path segment, but it becomes cumbersome if applied across two segments. It would be better and more precise if the controls at both ends were nodes. Another problem is that the path sometimes becomes unsmooth after such an offset, which also needs optimization.
3. Resetting the transformation center causes the graphics within the group to shift. Hope these issues can be resolved. Thank you.
@monsterfox I added these to the backlog
@VectorStyler https://youtu.be/xqaLZQQKzBI?feature=shared0_1760194883346_YY.vstyler
The expanded mixed graphics have experienced displacement
@monsterfox I added this to the backlog
@VectorStyler The Outline path tool seems to be not working。
Which tool is this?
@VectorStyler This is an effect, and it is in the same toolbar as the Offset Tool.
@monsterfox It seems to be working here, tested both Mac and Windows
@VectorStyler It’s strange that it isn’t working for me. I wonder if it’s caused by any settings I might have changed.
@monsterfox Send me your workspace and settings files by email.
