update 1.2.076
Uploaded a new build to fix a regression.
VectorStyler 1.2.076 release notes
- Added improvements to the Stroker Width tool.
 - Fixed a regression with Blended Shapes.
 - Fixed a bug in PDF file opening with composite shapes.
 - Fixed a style mixer color filter bug.
 - Fixed a regression in brush image effects editing.
 - Fixed UI text alignment issues on scaled displays.
 - Fixed regression in Color Bar panel action.
 - Scaling fields in Properties panel to accept negative values.
 - Fixed a bug in removing path sections betwen nodes.
 - Fixed a bug in adding nodes to a fully selected path.
 - Use previous known stroke width when adding a new stroke to an object.
 - Disable arrow position options if no arrow is selected.
 - Fixed a bug in using Arrange -> Extract Content on multiple objects.
 - Better lower limits for brush tool size shortcuts.
 - General stability improvements.
