Joining nodes when two they collide doesn't work
In ie. Blender (as far I know not in Adobe) one can set vector drawing to join nodes on/off when they collide or are collected in the drawing process. You can do this in VS too by pressing Option when dragging node – an utterly useful feature!
But it seems to work only when it concerns single shape entities. I cannot get it to work when I want to connect two shapes this way -- even if I combine (cmd-8) them in one object.
Am I doing something wrong?
@Raaskot Is this in the Pen tool or the Node tool?
It is both.
@Raaskot In this case the join can only be done by selecting both nodes (even if overlapping) and using the join command from the context panel (with the Node tool).
Should it be an option to join automatically?
