update 1.2.077
VectorStyler 1.2.077 release notes
- Fixed a PDF importing bug with rotated text
 - Improved pattern brush handling
 - Fixed a bug in importing pattern brushes from AI files
 - Fixed a selection bug in the path brush tool
 - Entering outline mode should not cancel duplication transform
 - Contour panel should create new contours with the current options
 - Typing text with paragraphs selected with triple click should replace the paragraphs
 - Ungrouping transformed text frames should keep the correct transformations
 - Show current width in stroke width panel when selecting with the stroke width tool
 - Selecting shape from the menu should keep the object position
 - Improved path combination options and speedup of certain path operations
 - Convert to curves should work also when the offset tool is active
 - Use the current transform each mode when flipping objects
 - Fixed a bug in the path eraser tool
 - Improved AI file importing with older AI formats
 - Selecting with the node tool in composited groups should not select the other objects of the group
 - Fixed an SVG exporting bug when exporting the whole canvas
 - Fixed an object duplication issue with moved parent layers
@VectorStyler Thank you! These are great fixes and improvements. Makes using VS a lot easier. I greatly appreciate the regular updates to VS!
Releases Page - Links Broken
MacOS - Ventura 13.7.7
Safari - 18.6 (18621.3.11.19.1, 18621)Hi:
For me all the download links for the 1.2.077 update on the releases page are broken. Tried all of them as a test.
Regards,
MWK
