update 1.2.080
VectorStyler 1.2.080 release notes
- Alternate tool to return to deep select tool if it was active
 - Fixed an error in undoing blend effects
 - Fixed an error in duplicating with the flip action from the context panel
 - Option to disable color palette name editing
 - Improved speed of some repeater types
 - Improvements for the proportional mode in the transform tool
 - Fixed a bug in noise fill previewing
 - Improved PDF importing
 - Fixed a bug in copy / pasting spot CMYK colors to another document
 - Decreasing the mesh distortion grid size should keep the existing mesh
 - Allow direct previewing in the path simplify tool
 - Fixed a crash caused by an OpenType font
 - Restored quadratic segment drawing mode using the Option(Alt) key
 - Fixed a regression with the crossing stroke option
@VectorStyler Issue on W11 for me. The install seems ok but VS doesn't launch (update or repair) . I suppose I have to remove VS and reinstall again ?
@B-Vs-V try removing and reinstalling.
@VectorStyler Not ok...
@B-Vs-V After uninstalling, remove all VectorStyler folder from Program Files \ NumericPath
@VectorStyler Another thing: after doing a clean install, go to the Program Files \ NumericPath folder and compress the whole VectorStyler1.2 folder. Send that to me by email, so I can check which part did not install correctly.
Also: there could be issues with the user data content (should not be), so you can try backing that up and removing it.
@VectorStyler There was no folder after uninstalling VS. I've sent you the crashlog files I did find.
There is a regression on Windows with the Glyphs panel causing the crash. I will try to upload a fix ASAP.
