update 1.2.085
VectorStyler 1.2.085 release notes
- Improvements in PDF text importing
 - Pick up brush color for default colors
 - Expand text style links when copying text to other documents
 - Do not deselect a node when switching between Anchor and Node tools
 - Do not show hidden shapes in group level styling
 - Expanding invisible brushes should not create object with brush content
 - Fixed a panel sizing bug on scaled screens
 - Transform pivot movement should not be repeated when duplicating
 - Fixed a regression in the mesh distortion editor tool
 - Fixed a bug in copying blend effects using symbols
 - Fixed a bug in iconified panel docking
@VectorStyler Thank you so much for looking at the transform around the pivot point. I tested it and I do not think it works as (I) intended, but perhaps I am missing something here. A video with the Ctrl+D duplication after a rotation with the rotate knob, vs setting same rotation in the panel: https://go.screenpal.com/watch/cT6hfKnD7gT
@syllie Something in the previous workspace or settings causes this, I can still replicate the issue on a machine where the precious workspaces were not deleted.
I will get back with more soon.
@syllie Can you send me your workspace files (last icon in context panel, Save Workspace).
@VectorStyler Done
