Retaining transparency when cutting shapes which include negative spaces
When you use the knife tool or break apart a shape which includes a negative shape for its transparent areas - i.e the letter "O" - the negative area will take a positive fill which then needs to be excluded manually using the boolean operations. This is manageable when it comes to simple objects, but when your shape includes a lot of transparent/negative areas you need to spend a lot of time figuring things out and re-excluding them from the base shape.
So if possible it would be great if the original positive/negative spaces are retained after using the knife tool like in Illustrator which seems to automatically punch-out the negative spaces. I know this isn't a quick fix, just putting it here for future consideration.
@Kyriakos I could not replicate this. If you could send me a file with the original shape and the shape where negative areas get filled it would help. Also: what is the fill mode of the object? even-odd or winding ?
@vectoradmin This is what i mean...
Have also problems with knife . Tested on few fonts, and results usually are different than expected. Need some improvements
Here's another example without type, the transparent area is resulting to a new shape instead of cutting just the positive space.
@vectoradmin playing with the updated knife tool now, it now properly cuts the relevant part on the "g" but that lower part is still taking a positive fill, is that supposed to happen? And on the square shape it seems to merge the negative space with the positive.
Also when multiple objects are cut some parts are deleted with only their edges remaining...
@Kyriakos I keep the issue open.
