Copy and Paste don't work as expected
I am currently working with text objects. I'll do a cut (command C) with a portion of the text, and that seems to work fine. But when I paste (command V) it won't show up. I'll have to go to the Edit>Paste and even that won't always work. Also, I can't seem to get it on the Targeted Layer all the time. The best success I've had on several paste attempts was when I was still on the same layer I was trying to move it from.
@buckycore Could not replicate this one, after a quick try.
Does the text contain any local formatting (changes in color or character style)?
What tool is selected when pasting?
I played with the height and size in the text frame before I did the copy and paste. However, That's all I did as far as formatting as I didn't play with Kerning nor spacing. However, it maybe it's from the font its self? Just a thought. The font is called TOXIA. I'm only using the first/default Font Tool, as it's a graphical font object I'm experimenting with
@buckycore If there is a sample document where this copy pasting issue can be replicated, it would help if you could send a link to it (on dropbox), or send it to be by email: csraba at vectorstyler.com
@vectoradmin Sure. Give me a moment and I will do so (FYI, I use MEGA, but it works the same as DropBox)
@vectoradmin Now it seems to be working fine. However, I had a linked Image in my original, but in the example, I'm about to send to you I removed it. However, to do the diagnostics correctly, I'd suggest Linking a large Image at 300dpi and see if that's that pertains to the issue.
@buckycore There have been fixes to the pasteboard in the new build (1.0.048). Let me know if this issue can still be replicated.
