Enhanced Color Palette Options: Color Values, Tints, Drag and Drop
User Interface Improvement:
@vectoradmin,
I would like to see VectorStyler add a few of Improvements to Color Palettes that are available in CorelDRAW:
1.Enhanced “Hovering” Color Value Information with Pop-up box:
- Color Name
 - Hex Value for RGB
Example:
2.Left Click and "Hold" on a Color Swatch in any Color Palette to get a "Pop-up" of all the Tints for that color.You can then select and apply the Tint to the Selected Object with a Left click for Fill and Right click for Stroke. The Selected Tint is indicated/highlighted with an Outline around it.
Here is an example:
3. With NO Selection, Click and Drag a Swatch from any Color Palette, "hover" over an object where you want it applied, and let go of the mouse button to Drop it in a Fill or Outline section of the object.When you first start to drag out a Swatch color, a “Filled” Color Box appears to the right of the Selection Arrow Icon Cursor and looks like this:
When you Hover over an Objects Outline, the Color Box Cursor changes to an Outlined Box with no fill.that looks like this:
@Vector-Rock These exist partially:
- Name or RGB values are shown
 - Drag&drop over non-selected objects applies as fill
I will add these to the backlog as improvements of existing features.
