High CPU usage for COG Shape
- Make a cog with 100 teeth
 - Make any change to the cog.
 - Very High CPU, around 340%
The same Cog with 100 teeth in Affinity Designer consumes around 110% when editing and does this smoother around 60fps. I don't know if it's because of the cog tool or maybe the viewport needs some optimizations when a lot is happening at the same time on the screen. Anyway, the tool functions very well if not taking into consideration that is quite power-hungry hahaha.
Thank you for your hard work
Added to the backlog. Maybe will lead to better performance
That would be awesome, to be honest, just imagining something as smooth as Affinity Designer but with a feature set that Rivals or Surpasses Illustrator, makes me very excited and hyped to finally have a True Illustrator Killer.
Hope I don't sound too arrogant with all those requests and critiques, I just really want this to be a great app for professional designers
All requests are welcome
They will be prioritized of course, bugs first, then features.
Performance is critical, but getting to AD level might not be feasible in the short run.
Maybe small improvements.
